- Laetitidu30Nouveau
- Nombre de messages : 7
Emploi : Ouvrier état
[ VW Polo 9n 1.2 16V essence an 2002 ] probleme démarrage (résolu)
Dim 12 Aoû 2018, 08:34
Bonjour ma polo ne démarre plus, voici le détail du diag qu'en pensez vous ?
VCDS-Lite Version: Release 1.2
Saturday, 11 August 2018, 16:59:11:0
Chassis Type: 9N - VW Polo
Scan: 01,02,03,08,09,15,17,19,25,37,44,45,46,56,76
Address 01: Engine Labels: Redir Fail!
Controller: 03E 906 033
Component: 1,2l/4V SIMOS3 00HS7000
Coding: 00071
Shop #: WSC 05860
VCID: DDCD9A774429
XXXXXXXXXXXXXXX VWZ7Z0B5187655
8 Faults Found:
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 35-10 - - - Intermittent
16517 - Oxygen (Lambda) Sensor B1 S1: Response too Slow
P0133 - 35-00 - -
16555 - Fuel Trim; Bank 1: System Too Lean
P0171 - 35-10 - - - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
17511 - Oxygen (Lambda) Sensor Heating; B1 S1: Performance too Low
P1103 - 35-10 - - - Intermittent
16554 - Fuel Trim; Bank 1: Malfunction
P0170 - 35-10 - - - Intermittent
16502 - Engine Coolant Temp. Sensor (G62): Signal too High
P0118 - 35-10 - - - Intermittent
16726 - Camshaft Position Sensor (G40): Signal too Low
P0342 - 35-10 - - - Intermittent
Readiness: 0010 0001
Address 03: ABS Brakes Labels: 6Q0-907-37x-ABS.LBL
Controller: 6Q0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0001097
Shop #: WSC 00788
VCID: 46FFD51B71BF
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Address 08: Auto HVAC Labels: 6Q0-820-045.LBL
Controller: 6Q0 820 045
Component: Klimaanlage X0840
VCID: EAA7C1AB8567
3 Faults Found:
01596 - Motor for Outside/Recirculated Air Flap (V154)
30-00 - Open or Short to Plus
41-10 - Blocked or No Voltage - Intermittent
29-10 - Short to Ground - Intermittent
Address 09: Cent. Elect. Labels: 6Qx-937-049-B.LBL
Controller: 6Q1 937 049 C
Component: 00 BN-SG. 1S32
Coding: 25758
Shop #: WSC 00788
VCID: 3B09B4EF3A7D
2 Faults Found:
01598 - Drive Battery Voltage
07-10 - Signal too Low - Intermittent
27-10 - Implausible Signal - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.LBL
Controller: 1C0 909 605 K
Component: 0M AIRBAG VW51 0P 0004
Coding: 12365
Shop #: WSC 00788
VCID: 2C2B87B3CF13
No fault code found.
Address 17: Instruments Labels: 6Q0-920-xxx-17.LBL
Controller: 6Q0 920 800 Pw
Component: KOMBI+WEGFAHRSP VDO V13
Coding: 01131
Shop #: WSC 05348
VCID: C5FD5217CCB9
XXXXXXXXXXXXXXXXXXXX VWZ7Z0B5187655
Address 19: CAN Gateway Labels: 6N0-909-901-19.LBL
Controller: 6N0 909 901
Component: 02 GATEWAY CAN 1S32
Coding: 00014
Shop #: WSC 00788
VCID: F093D3C3A3BB
Address 25: Immobilizer Labels: None
Controller: Bit teA dre ssw
Component: e 17 eingeben
VCID: D1D5764708F1
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 44: Steering Assist Labels: None
Controller: 6Q0 423 156 M
Component: LenkhilfeTRW V210
Coding: 00140
Shop #: WSC 00788
VCID: 3905AEE73041
Address 45: Inter. Monitor Labels: 6Q0-951-171.LBL
Controller: 6Q0 951 171
Component: Innenraumueberw. 0018
VCID: EF91D0BFBE85
Address 46: Central Conv. Labels: 6Q0-959-433.LBL
Controller: 6Q0 959 433 E
Component: 3M Komfortgerát 0001
Coding: 00067
Shop #: WSC 00788
VCID: 3D0DBAF72469
End ------------------------
Coding: 00071
Shop #: WSC 05860
VCID: DDCD9A774429
8 Faults Found:
P0133 - 35-00 - -
Coding: 0001097
Shop #: WSC 00788
VCID: 46FFD51B71BF
1 Fault Found:
VCID: EAA7C1AB8567
3 Faults Found:
Coding: 25758
Shop #: WSC 00788
VCID: 3B09B4EF3A7D
2 Faults Found:
Coding: 12365
Shop #: WSC 00788
VCID: 2C2B87B3CF13
Coding: 01131
Shop #: WSC 05348
VCID: C5FD5217CCB9
Coding: 00014
Shop #: WSC 00788
VCID: F093D3C3A3BB
VCID: D1D5764708F1
No Faults Found
Coding: 00140
Shop #: WSC 00788
VCID: 3905AEE73041
VCID: EF91D0BFBE85
Coding: 00067
Shop #: WSC 00788
VCID: 3D0DBAF72469
- albatrosTech-modo
- Nombre de messages : 7871
Re: [ VW Polo 9n 1.2 16V essence an 2002 ] probleme démarrage (résolu)
Dim 12 Aoû 2018, 09:07
Laetitidu30
De quel est le kilométrage général de cette POLO
Vous écrive, je cite: ma polo ne démarre plus, voici le détail du diag qu'en pensez vous
A part le " Diag " , il faudrait nous en écrire plus sur cette panne ... depuis quand ne démarre t'elle plus es-ce suite à une intervention mécanique .... a t'elle donnée des signes de dysfonctionnement ou cette une panne brutale
Le démarreur fonctionne t'il normalement mais le moteur refuse de démarrer
A suivre ...
Dim 12 Aoû 2018, 09:49
Bo je la voiture à 150000 km, on l’a déplacé à la maison et 5 minutes après elle ne démarrait plus, sans signe avant coureur ni bruit particulier, le démarreur fonctionne, on a de l’allumage.
- albatrosTech-modo
Dim 12 Aoû 2018, 10:24
D'accord mais il faut un second ingrédient pour la faire démarrer ... le carburant arrive t'il
Sinon démarre t'elle en la poussant en enclenchant la seconde vitesse ou en la câblant sur un autre véhicule dit de Secours
A suivre ...
Dim 12 Aoû 2018, 10:31
Le carburant arrive bien et elle ne démarre pas en la poussant car elle ne tousse pas
- albatrosTech-modo
Dim 12 Aoû 2018, 11:05
Il y a t'il un antidémarrage justement qui l'empêcherait de démarrer (voyant au tableau de bord) s'il est actif la POLO ne démarrera pas ... car dans le DIAG il y a ce message
Engine Start Blocked by Immobilizer = :Démarrage du moteur bloqué par un antidémarrage ?: c'est la cause probable qu'elle ne démarre pas
A suivre ...
Dim 12 Aoû 2018, 11:12
Aucun voyant sur le t l’eau de bord, on a essayé de démarrer avec la seconde clé et c’est pareil
- albatrosTech-modo
Dim 12 Aoû 2018, 11:23
tant que l'antidémarrage sera actif (lEngine Start Blocked by Immobilizer) la POLO ne démarrera jamais ... vous allez vider la batterie c'est tout ...
A suivre ...
A suivre ...
Mer 15 Aoû 2018, 22:25
Bonsoir on a réparé la voiture, en fait on a changé la chaîne de distribution et tout est rentré dans l’ordre.
- albatrosTech-modo
Jeu 16 Aoû 2018, 08:18
Bonjour Laetitidu30
Merci pour le retour d'information cela veut dire que la chaîne de distribution HS avait certainement sauté d'une dent donc décaler la distribution de ce fait impossible de démarrer le moteur de la POLO ... vous confirmez
Jeu 16 Aoû 2018, 08:47
Oui c’est tout à fait ça je dirai plutôt le tendeur était hs et la chaîne avait bien sauté effectivement
Si ça peut servir aux autres personnes
- albatrosTech-modo
Jeu 16 Aoû 2018, 09:13
Bonne continuation avec votre POLO
Jeu 16 Aoû 2018, 10:15
Sam 18 Aoû 2018, 07:28
Merci pour le retour d'infos
Sujet répertorié ici : www.techniconnexion.com/t16596-problemes-resolus-et-fiches-pratiques-moteur-vw
