- maroin66Nouveau
- Nombre de messages : 3
Emploi : aid commercant
[ VW caddy life TDI 105 an 2007 ] probleme perte de performance
Ven 13 Juil 2012, 01:36
Salut tous le mande svp j’ai un caddy life TDI 105 moteur BLS ces dernier temps j’eu des problemes de perte de puissance ainsi que des raté d’accélération.
Après un diagnostic j’ai eu cette résultat suivant
Wednesday,11,July,2012,12:30:41:26365
VAG-COM Version: Release 704.1
Address 01: Engine
Control Module Part Number: 03G 906 021 AQ
Component and/or Version: R4 1,9l EDC 000SG 7872
Software Coding: 0000071
Work Shop Code: WSC 35110
2 Faults Found:
001031 - EGR Potentiometer (G212): Signal too Low
P0407 - 000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 5
Mileage: 193590 km
Time Indication: 0
Date: 2000.00.00
Time: 11:03:40
Freeze Frame:
RPM: 1281 /min
Speed: 9.0 km/h
Load: 35.7 %
Lambda: 1.4 %
Mass Air / Rev.: 495.0 mg/str
Mass Air / Rev.: 520.0 mg/str
Bin. Bits: 00000000
001027 - EGR Valve (N18): Malfunction
P0403 - 000 - - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Mileage: 193594 km
Time Indication: 0
Date: 2000.00.00
Time: 11:23:3
Freeze Frame:
RPM: 2772 /min
Speed: 119.0 km/h
Duty Cycle: 0.0 %
Voltage: 14.36 V
Mass Air / Rev.: 850.0 mg/str
Duty Cycle: 34.7 %
Bin. Bits: 00000000
Readiness: 0 0 0 0 0
A noté que je viens de changer la vanne EGR par un neuf mais toujours même problème
y a t'il autre cause possible ? ? ?
Address 01: Engine
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 5
Mileage: 193590 km
Time Indication: 0
Date: 2000.00.00
Time: 11:03:40
Freeze Frame:
RPM: 1281 /min
Speed: 9.0 km/h
Load: 35.7 %
Lambda: 1.4 %
Bin. Bits: 00000000
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Mileage: 193594 km
Time Indication: 0
Date: 2000.00.00
Time: 11:23:3
Freeze Frame:
RPM: 2772 /min
Speed: 119.0 km/h
Duty Cycle: 0.0 %
Voltage: 14.36 V
Duty Cycle: 34.7 %
Bin. Bits: 00000000
Re: [ VW caddy life TDI 105 an 2007 ] probleme perte de performance
Ven 13 Juil 2012, 05:29
Tentes de débrancher le débitmètre.
- maroin66Nouveau
Mar 17 Juil 2012, 18:07
j'ai débranché la conection de la vanne pui j'ai fait un teste la voiture roul bien sans aucun problemm sof l il me signal un problm sur le tableau
- maroin66Nouveau
Mar 17 Juil 2012, 18:14
Y’a-t-il autre moyen pour teste ma vanne si il marche bien pour être sur que ce n pas la vanne a noté que ma vanne est électrique de marque pierburg
Jeu 19 Juil 2012, 01:19
De quelle vanne parles-tu ?
